8 members (Donf, Gdads51, 55shaker, FAST55, Ponchogl, Wickedbass, Cosmo, Hanks custodian), 66 guests, and 5 robots.
Topics128,065
Posts1,055,868
Members48,428
#210927 06/30/2006 10:45 PM
'51, 3100, 235...I was driving around this morning, in town, 30 mph. When I had to slow for a car in front, I downshifted to 3rd gear. Just as I started to accellerate, I felt a "bump" and heard a noise. The truck started a howling that was sickening. I had to drive it for a block. It only howls when on even throttle or accellerating. With my head out the window it sounds like Tranny (SM420).
Will someone please tell me what I might start looking for? I was gonna drive it to K.C, MO tomorrow but that is out.
Thruwurkin
Kennewick, WA
My apologies. This should have been posted in the "Engine/Driveline" area.
Half Ton Will Travel
God bless America...One nation under God
#210928 06/30/2006 10:53 PM
Thruwurkin,
If this series has a torque tube setup, my bets would be on the u-joint. I guess your not through working. eek
Stuart
#210929 06/30/2006 10:55 PM
put it on jack stands, check for a loose drive line, put it in gear and turn the wheels by hand...
if you cant find out that way, I would fire it up and run it through the gears and see what falls out... (very carefully)
Another quality post.
Real Trucks Rattle
#210930 07/01/2006 4:19 AM
It is now up on jack stands and I won't do anything with it till late next week. It is 100 degrees + in the garage and I have a million things to do before I leave for K.C. in the morning.
Thanks so much for the help. I'll keep you posted.
Thruwurkin
Kennewick, WA
#210931 07/08/2006 2:44 AM
Today I ran the '51 while it was up on jack stands. Got a lot of noise from the front on the driveline and it got worse as I went back. I pulled the inspection plate off and guess what!! I could move the ring gear up and down about 1/2 inch. I have no idea how it could not have come apart.
Monday I'll order 3.55 gearset and installation kit from Patrick's.
I don't have the special tools/pullers to do the job so it's off to a machine shop to get done.
Thanks again for the advice.
Thruwurkin
Kennewick, WA
