1 members (53 green 1- ton),
110
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 145 | '51, 3100, 235...I was driving around this morning, in town, 30 mph. When I had to slow for a car in front, I downshifted to 3rd gear. Just as I started to accellerate, I felt a "bump" and heard a noise. The truck started a howling that was sickening. I had to drive it for a block. It only howls when on even throttle or accellerating. With my head out the window it sounds like Tranny (SM420).
Will someone please tell me what I might start looking for? I was gonna drive it to K.C, MO tomorrow but that is out.
Thruwurkin Kennewick, WA
My apologies. This should have been posted in the "Engine/Driveline" area.
Half Ton Will Travel God bless America...One nation under God
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Thruwurkin, If this series has a torque tube setup, my bets would be on the u-joint. I guess your not through working. Stuart | | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | put it on jack stands, check for a loose drive line, put it in gear and turn the wheels by hand...
if you cant find out that way, I would fire it up and run it through the gears and see what falls out... (very carefully)
| | | | | Joined: Jun 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 145 | It is now up on jack stands and I won't do anything with it till late next week. It is 100 degrees + in the garage and I have a million things to do before I leave for K.C. in the morning.
Thanks so much for the help. I'll keep you posted.
| | | | | Joined: Jun 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 145 | Today I ran the '51 while it was up on jack stands. Got a lot of noise from the front on the driveline and it got worse as I went back. I pulled the inspection plate off and guess what!! I could move the ring gear up and down about 1/2 inch. I have no idea how it could not have come apart.
Monday I'll order 3.55 gearset and installation kit from Patrick's.
I don't have the special tools/pullers to do the job so it's off to a machine shop to get done.
Thanks again for the advice.
