6 members (Otto Skorzeny, Woodcmiami, Gray_Ghost, Hanks custodian, 1955 1 Series, Forty9), 149 guests, and 9 robots.
Topics128,077
Posts1,056,031
Members48,433
#210602 06/26/2006 3:14 AM
Junior Member
Junior Member
'50 3100. While trying to remove/ replace the parking brake linkage I cannot separate the sections of rod that run beneath the cab. I have removed the cotter pins, but they dont seem to matter b/c the clevis pins do not move. Is this rust or is this operator error?
Thanks gents,
Miles
#210603 06/26/2006 3:15 AM
Junior Member
Junior Member
"Thanks gents,"
AND ladies!
Miles
#210604 06/26/2006 5:33 AM
Rust.
#210605 06/26/2006 2:54 PM
those clevis's do not adjust. just remove the pins and take them apart.
Jim & Caroline
#210606 06/26/2006 5:21 PM
Junior Member
Junior Member
No amount of PB blaster and bfh would remove the clevis pins from the clevis. In fact I bent the rod trying to get these suckers apart.
I guess the stainless replacement f/ Jim Carters is added to the list!
#210608 06/26/2006 5:40 PM
I had the same problem when I took mine apart. Couldn't get them to move with heat, PB Blaster, and lots of force. But the 4" cutoff wheel did the trick. I needed to get that piece out of the way so I could ship the cab off to the sandblaster.
Replacements are on my list as well.
1950 Chevrolet 3100 "One Step Forward, Two Steps Back"
Webshot Photos
