1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 11 Junior Member | | Junior Member Joined: May 2006 Posts: 11 | '50 3100. While trying to remove/ replace the parking brake linkage I cannot separate the sections of rod that run beneath the cab. I have removed the cotter pins, but they dont seem to matter b/c the clevis pins do not move. Is this rust or is this operator error?
Thanks gents,
Miles | | | | | Joined: May 2006 Posts: 11 Junior Member | | Junior Member Joined: May 2006 Posts: 11 | "Thanks gents,"
AND ladies!
Miles | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | those clevis's do not adjust. just remove the pins and take them apart.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: May 2006 Posts: 11 Junior Member | | Junior Member Joined: May 2006 Posts: 11 | No amount of PB blaster and bfh would remove the clevis pins from the clevis. In fact I bent the rod trying to get these suckers apart.
I guess the stainless replacement f/ Jim Carters is added to the list! | | | | | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | I had the same problem when I took mine apart. Couldn't get them to move with heat, PB Blaster, and lots of force. But the 4" cutoff wheel did the trick. I needed to get that piece out of the way so I could ship the cab off to the sandblaster.
Replacements are on my list as well. | | |
