4 members (Tronman, tclederman, Hotrod Lincoln, JW51), 149 guests, and 3 robots.
Topics128,042
Posts1,055,511
Members48,424
#210423 06/23/2006 4:59 AM
I really need to pick some brains on this one. I found a set of rims that were on a burnt out truck. The tires were completely burnt off.The main question I have is are they safe to use again or has the heat taken the temper out to where they are weak. Is there any metallurgists out there. Any help would be appreciated
#210424 06/23/2006 6:39 AM
I am no meturllurgist...but I would say...don't use them. Fire and Rims is a bad combo. If you do the math on how hot the rims were to burn the tires off, who knows what happened to the metal in the process. For the amount of time and money you will spend on repainting, mounting and balancing alone, you will be paying a lot of what new rims from Chevs of the 40's would cost if you have to start over.
There are rims out there that have not been in a fire...keep hunting and get a better set. My $.02.....
#210425 06/23/2006 1:15 PM
Thanks that confirmed what I thought cool
#210426 06/23/2006 4:29 PM
If there's any doubt to the integrity of a rim, then definitely don't use it.
#210427 06/23/2006 4:33 PM
I would use a burnt rim on a tractor maybe, but not on anything higher speed than that,,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
