7 members (Donf, Hanks custodian, Cosmo, Gray_Ghost, treegrower, Bill Hanlon, 1 invisible),
105
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 87 | hi all cant decide what motor to run in my 49 3100
it needs to pull well go well cruise at 70 all day be happy in traffic AND give good mileage can anybody tell me what sbc set ups could do this? (nothing exotic) manual or auto and a good cam for torque/mileage what sort of mileage are u guys getting?
also whats best axle ratio? thanks | | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | I have a '49 3100, '56 235 6 cylinder, '848 head', Fentons, dual 30" glasspacks, '62 3sp+od, '57 3.90 diff., 1-2bbl H-W, 215 85R 16 Michelins (no tubes needed). I drive 70-75 all day (two 900 mile trips so far this year)20 mpg highway.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | he says good mileage !!!!!!!
250 or 292 L6 motor T5 or NV4500 5 speed 10 or 12 bolt rear set the motor up any way you can afford to.
gl
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | Blown 454 with a built 700R4.
| | | | | Joined: Apr 2006 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 87 | well i think i got a wheezer 216 so was thinking of a 283 or 305 /350 v8 just wondering what mileage to expect and whats a good cam choice | | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | I've got the Edelbrock cam, 2101 intake and 600cfm carb setup on my 283... but my mileage sucks, because the carb is messed up..
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I have a 350 SB and a built 700R4 in my 55 2nd.3:90 rear.20 MPG will cruise at any speed you desire. | | | | | Joined: Jun 2006 Posts: 10 New Guy | | New Guy Joined: Jun 2006 Posts: 10 | The 700R4 transmission gave me a little increase and the TBI system that replaced my Q-jet gave me another increase but I'm still only getting 14-15 on the highway with my 350 ('65 C20). | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | persh,what gear ratio is your rear? | | | | | Joined: Jun 2006 Posts: 10 New Guy | | New Guy Joined: Jun 2006 Posts: 10 | Hey, I didn't want to answer your quesiton too quickly!! (Sorry, I haven't been around here much lately). I installed a Dana 60 with a 3.54 gear set. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | what do you consider good mileage? I do know small block chevy and good mileage should never go in the same sentence. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Why shouldn't a small block get good mileage? Set up right they should be very good on fuel mileage.
| | | | | Joined: Feb 2000 Posts: 5,209 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,209 | You are going to get 100 different answers to the fuel milage question. I would bet no more then about 20 at the best and most likely about 15 to 17. The truck is pushing a ton of air so no matter what engine you give it, its going to have to work harder then a modern truck would. My 250 with automatic and 3.08 gear gets 18 at 70 mph in a 3300 lb truck.
Joe | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I am of the opinion that if you are driving one of these you aren't really concerned with fuel economy, I don't feel less than 30 mpg should be regarded as good mileage. If this is just a toy thats one thing, but if you are going to use it as a daily driver, I consider 20 mpg nearly criminal. (yes I put suburbans, expeditions and the rest of them in that category) But that is just me, the sheer number of them on the road makes its own statement. I am pretty upset I only get 34 mpg in my little bitty car, the truck I don't even want to know...but then I only drive it occasionally. To each his own, that is just my feelings. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | You say you want to be able to haul a load and cruise confortably at highway speeds so some type of overdrive is a must. The 3.90 rear mentioned is a good choice as this gives a 2.73 final in od which is about as shallow a gear as can be pulled comfortably with a load and a stock 350. Radial tires at recommended pressure, synthetic oils and fluids, free flowing exhaust, coolant temp as high as possible without losing any, FUEL INJECTION, no sun visor/west coast mirrors/bug shields or other air catchers and your driving style will all be factors. Why the hang up on 350's when the newer LS engines are so much better and give great mileage right out of the box. It's the reason GM canned the old sbc design. Price and electronics would be my guess but the results are undeniable.
Evan
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Reminder: This forum is about old Chevy trucks. If you want to discuss the mileage you get in your modern vehicles, please do it in the Greasy Spoon. Please limit this to a discussion on how to improve mileage in our old trucks.
Thanks. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | ok fine! I recommend the 350 w/tbi and either standard transmission already mentioned. The original question is all about a modern drive train or modifications.  | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | OK, I'll move it to HiPo then. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | So how about undeleting my original post? Bet ya can't do that. | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | my advice is a good strong 350 with a rv cam and maybe a expertly built q-jet and a recurve hei. run the 700 r4 with maybe a 3.70 or 3.55 gear. whenpulling the load run in drive not overdrive. it will kill the mileage but save the tranny. and as always let it breath well. long tube headers with free flowing exhaust and a good fresh air intake system. i would bet once tuned right it will run in the 20's. i ran this setup with out the headers and fresh air system in my 82 chevy and got 18-19 consistently. so with the extras i would add a few more mpg.
MO's 1951 chevy 3100 resto mod project
| | | | | Joined: Feb 2012 Posts: 2 New Guy | | New Guy Joined: Feb 2012 Posts: 2 | I've got a 48 3100 running a 283, quadrajet, headers, TR700 and 3:90 gears. It'll run 70 all day long but that big ole visor on the front acts just like a big ole wind brake, so I'm only getting 11/12 at best on the highway. Remember they didn't build those things with aerodynamics in mind, it was a work truck. I'm pretty sure the highway speed limit in 1949 was 50 mph. I would agree that if you think you can have all that you'll have to be thinking LS ....
Seeing the USA in my (48, 3100, highly modified) Chevrolet!
