1 members (NJC),
125
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2002 Posts: 19 New Guy | | New Guy Joined: May 2002 Posts: 19 | On my 1950 Chevy 3/4 ton when I hit the brakes, it pull pretty hrad to the LEFT. When I jack up the front end, the RIGHT wheel won't turn as if the brakes aren't releasing. Any thoughts?
Thanks, Jon | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Time to pull it apart and see what's inside the drums. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Could be a collapsed hose or stuck wheel cylinder. Pull the wheel off and check the wheel cykinder for freedom of movement. If it is't stuck then the hose is most likely the problem. I would suggest replacing both hoses as preventative maintainance.
Bill Burmeister | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | With the stuck wheel off the ground loosen the bleeder screw, did it freeup? If so replace the hose. If it didnt freeup check the wheel cyl. and the adjustment.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: May 2002 Posts: 19 New Guy | | New Guy Joined: May 2002 Posts: 19 | Good idea Toyvo. I'll try that first next time I get some time in the garage. Thanks. | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | check your return springs. If the main one is broken, you can get stuff like that happening. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | My advice is to stop driving the truck until you do a complete brake job on it. | | | | | Joined: May 2002 Posts: 19 New Guy | | New Guy Joined: May 2002 Posts: 19 | cletis, I'm definitely not driving it around like this. I was away at school for the last two years and after getting it running again I noticed this problem on my test drive yesterday | | |
