2 members (klhansen, Otto Skorzeny), 47 guests, and 1 robot.
Topics128,036
Posts1,055,452
Members48,422
#209923 06/13/2006 8:35 PM
On my 1950 Chevy 3/4 ton when I hit the brakes, it pull pretty hrad to the LEFT. When I jack up the front end, the RIGHT wheel won't turn as if the brakes aren't releasing. Any thoughts?
Jon
#209924 06/13/2006 8:40 PM
Time to pull it apart and see what's inside the drums.
#209925 06/13/2006 8:43 PM
Could be a collapsed hose or stuck wheel cylinder. Pull the wheel off and check the wheel cykinder for freedom of movement. If it is't stuck then the hose is most likely the problem. I would suggest replacing both hoses as preventative maintainance.
Bill Burmeister
#209926 06/13/2006 8:55 PM
With the stuck wheel off the ground loosen the bleeder screw, did it freeup? If so replace the hose. If it didnt freeup check the wheel cyl. and the adjustment.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#209927 06/13/2006 9:57 PM
Good idea Toyvo. I'll try that first next time I get some time in the garage. Thanks.
#209928 06/14/2006 1:57 AM
check your return springs. If the main one is broken, you can get stuff like that happening.
#209929 06/14/2006 2:38 AM
My advice is to stop driving the truck until you do a complete brake job on it.
#209930 06/14/2006 3:07 AM
cletis, I'm definitely not driving it around like this. I was away at school for the last two years and after getting it running again I noticed this problem on my test drive yesterday
