1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
#209590 06/09/2006 1:19 AM
hey guys, i've come to a cross roads in my project.
its a '69 K20, getting a '67 front clip.
however, the front axle is a wee bit messed up. leafs at the wrong angle, a shackle being bent. along with the front driveshaft needing a new CV, and needing new tie rod ends. along with brakes, etc.
so, this is where i began thinking.
should i swap out a 2wd frame?
i have a '67 1/2 ton, and a '68 3/4 ton for frames.
right now my project only concists of a running gears, rad support, and cab on frame. so, it wouldn't exactley be a terribly hard swap.
could ig et some opinions please? this is just a hair brained idea that i ran past my dad, and i'd like some extra input.
thanks!
.sam.
1969 K20 , with a '67 front clip. fleetside. 292, 3x1 offy, headers. sm465 4spd. getting put back together, almost ready for paint.
doing it all myself.
19 and lovin' it.
"proper" is so over-rated.
.later days.
.sam.
#209591 06/09/2006 3:25 AM
Opinions? Everybody's got one. I'd go with the '67 ½-ton frame and sell the 4WD parts to help finance my project.
My opinion is based on the fact that I own a running '83 Jimmy 4WD and haven't fired it up in months and haven't tagged it in years.
#209592 06/09/2006 3:32 AM
A LOT more aftermarket parts available for the 1/2 ton which is why it would be my choice. But what really matters is how you want to use it.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#209593 06/09/2006 5:28 AM
It really depends on how you use the truck. If you want to sling mud or play on the streets, anything is possible with a cutting torch & a welder.
