Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (dt235sd, Sjm), 99 guests, and 2 robots.
Topics128,283
Posts1,058,505
Members48,490
#209182 06/06/2006 10:31 PM
I notice that the gas tank filler necks of '49's don't all come out at the same place. I take it that 49 was the change over year. Some of them come out of the cab and others come out of the bed. Someone know the story on this? Cecil........
#209183 06/06/2006 11:50 PM
I
I Offline
I have a 48 truck with the tank behind the seat. I would guess that since several palnts made the trucks, the change might not have happened all at the same time.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#209184 06/06/2006 11:56 PM
i believe only one year (49) they did come out the side, low in front of the fender, an under bed tank.
i changed mine back to under the bed, between the frame rails on the 51.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=004653;p=1#000006
Jim & Caroline
#209185 06/07/2006 2:09 AM
I
I Offline
47 and 48 are the only offically listed yrs for a tank under the bed of the smaller trucks, inside the frame. Bigger trucks used ones outside the frame. The restore pac lists 49's as having it in the cab.
Jeff
1953 3/4-ton
#209186 06/07/2006 2:41 AM
If it's an early production '49 it may have been registered by the year of manufacture, rather than the model year. Some states did it that way. Some times guys will register a '49-'43 as a '48 to get past athe '48 model year cutoff for the hot rod shows/clubs.
Bill Burmeister
