0 members (),
187
0
Mod | | | Forums66 Topics128,274 Posts1,058,425 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I notice that the gas tank filler necks of '49's don't all come out at the same place. I take it that 49 was the change over year. Some of them come out of the cab and others come out of the bed. Someone know the story on this? Cecil........ | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | I have a 48 truck with the tank behind the seat. I would guess that since several palnts made the trucks, the change might not have happened all at the same time. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i believe only one year (49) they did come out the side, low in front of the fender, an under bed tank. i changed mine back to under the bed, between the frame rails on the 51.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=004653;p=1#000006
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | 47 and 48 are the only offically listed yrs for a tank under the bed of the smaller trucks, inside the frame. Bigger trucks used ones outside the frame. The restore pac lists 49's as having it in the cab. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If it's an early production '49 it may have been registered by the year of manufacture, rather than the model year. Some states did it that way. Some times guys will register a '49-'43 as a '48 to get past athe '48 model year cutoff for the hot rod shows/clubs.
Bill Burmeister | | |
