| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | 1958 1 ton dually with 8 x 6.5 bolt pattern. Hub centered 19.5" rims.
So I was able to break free the 8 nuts (front wheels) that look like the lug nuts I've removed before on cars. I know these are not lug nuts, cause it's a hub centerd rim. When those where all free, I was not able to remove the rim. I banged on it with a minor amount of force, but no go. What am I missing? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Common ocurance on the duallys. Spray it with a penatrant. Turn the wheels sharp to one side & get under it with a really big hammer & hit the wheel from inside. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | Yes this is a very common problem with these old trucks. Spray the outer hub are with PB Blaster, dont be shy about it. I ussallly put a jake between the frame and the back of the rim, and give it a little pressure. Hit it with a good size maul where the tire meets the rim. This rim is about 5/16" thick at the hub center, so theres a lot of area that will be holding. I've also used a port-o-power instead of the jack. Just push againtst the back of the rim, release it, then turn the wheel to a new place. Ussally come off pretty easy after saoking and some pressure is applied. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | We use a 10 pound sledge in our shop for this problem. Give it a good whack, then rotate the wheel 90 degrees and repeat until the wheel comes off. Leave 1 nut on loosely sp the wheel doesn't fall completely off for safety. Don't be shy about hitting it either, like I tell the young guys I work with-"Hit it like your'e gonna kill it". When you put the wheels back on, put a light coat of anti-seize compound-Permatex is good-on the hub and centering flats. That will help keep them from seizing on. Make sure that you have the truck supported on proper capacity stands when you do this, get the 5-ton or better stands. Well worth the cost.
Bill Burmeister | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Hit it like it owes you money, Scott | | | | | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | Thanks guys, that did the trick.
My front drums have what appears to be a spacer on them. I am assuming to space out the front wheel due to the offset of the rims necessary for the dually's in the back. Yep... these are locked down tight also. I got the nuts to loosen last night. Tonight I'll put back on the rims and get to hammering with the sledge again to break the spacer free.
To break old tractor rear tire free you loosen the nuts so a little gap is present, then go drive around in figure 8's. Works every time. | | |
