4 members (1955 1 Series, 66flea, UtahYork, Deegs53), 359 guests, and 4 robots.
Topics128,156
Posts1,057,018
Members48,460
#208880 06/02/2006 12:25 AM
so i took my starter off and forgot which wires go where..
does anyone have picutres or a diagram of what it should look like??
thanks in advance
Mike, if it hasn't had any additional wires put on there should just be three wires. The battery cable, the main feed wire which has a large ring terminal that fits on the post with the battery cable, and a wire with a small ring terminal that fits on a stud on the side of the starter switch. This wire goes to the coil and gives it a full 12 volts while the starter is engaged.
Evan
