| | | Forums66 Topics128,162 Posts1,056,925 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 95 Member | | Member Joined: Feb 2005 Posts: 95 | so i took my starter off and forgot which wires go where..
does anyone have picutres or a diagram of what it should look like??
thanks in advance | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Mike, if it hasn't had any additional wires put on there should just be three wires. The battery cable, the main feed wire which has a large ring terminal that fits on the post with the battery cable, and a wire with a small ring terminal that fits on a stud on the side of the starter switch. This wire goes to the coil and gives it a full 12 volts while the starter is engaged.
Evan
