1 members (LAROKE),
127
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | Where can I get shoulder/lap belts to replace the lap belts in my '70 C10?
I will be finished with my truck soon and after using the shouler/lap style belts for so long, I just don't feel comfortable with the old seats belts that came in the truck. | | | | | Joined: Feb 2002 Posts: 2,897 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,897 | This is an option for shoulder belts. Do you have a bench seat or buckets? They have both... maybe call and ask them about your application. http://www.julianos.com Also check out the 'links' at the top of the stovebolt page, then 'parts'. -W | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | There were recently two lengthy discussions about shoulder belt installs in earlier trucks than yours, but the same info applies. Here's one of the threads.
In addition to Julianos, you can look on ebay, pull a set from the junk yard, or get them from NAPA. Keep in mind the length and attachment of all belts is not the same. Some retractors bolt to the body, others to the floor. Some of the shoulder attachmemts incorporate 'extensions' and others don't. etc...
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=20;t=000471
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | Thanks for the help. I checked out the Juliano's site and I like the set they offer for my truck. I will check out other options before deciding which ones to purchase. | | | | | Joined: Dec 2004 Posts: 56 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 56 | Julianos...they worked great in my truck, and the price was good. | | | | | Joined: Feb 2002 Posts: 2,897 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,897 | Juliano's kits also have that nifty part that keeps the bolts from pulling through the sheet metal if there is ever an actual accident.
-W | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Anyone have input on whether I should get a retractable or just a regular 2 point belt? | | |
