4 members (GMCJammer51, 54farmtruck, 2-Ton, treegrower), 74 guests, and 3 robots.
Topics128,196
Posts1,057,395
Members48,471
#208691 05/30/2006 3:27 AM
Where can I get shoulder/lap belts to replace the lap belts in my '70 C10?
I will be finished with my truck soon and after using the shouler/lap style belts for so long, I just don't feel comfortable with the old seats belts that came in the truck.
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
#208692 05/30/2006 5:07 AM
Socket Breaker
Socket Breaker
This is an option for shoulder belts.
Do you have a bench seat or buckets? They have both... maybe call and ask them about your application.
http://www.julianos.com
Also check out the 'links' at the top of the stovebolt page, then 'parts'.
-W
#208693 05/30/2006 9:40 PM
There were recently two lengthy discussions about shoulder belt installs in earlier trucks than yours, but the same info applies. Here's one of the threads.
In addition to Julianos, you can look on ebay, pull a set from the junk yard, or get them from NAPA. Keep in mind the length and attachment of all belts is not the same. Some retractors bolt to the body, others to the floor. Some of the shoulder attachmemts incorporate 'extensions' and others don't. etc...
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=20;t=000471
#208694 05/30/2006 9:49 PM
Julianos
Jim & Caroline
#208695 05/31/2006 1:27 AM
Thanks for the help. I checked out the Juliano's site and I like the set they offer for my truck. I will check out other options before deciding which ones to purchase.
Ralph Davis
#208696 06/01/2006 6:53 AM
Julianos...they worked great in my truck, and the price was good.
#208697 06/01/2006 12:29 PM
Socket Breaker
Socket Breaker
Juliano's kits also have that nifty part that keeps the bolts from pulling through the sheet metal if there is ever an actual accident.
-W
#208698 06/02/2006 10:11 PM
Anyone have input on whether I should get a retractable or just a regular 2 point belt?
