3 members (kbenz, JW51, Gib70), 168 guests, and 1 robot.
Topics128,108
Posts1,056,238
Members48,437
#208683 05/30/2006 1:13 AM
Well ,all the mounts are done and today I pulled the mill out so I can do the firewall. First all the bondo to cover all the new welded panels and then primer. As I primered the firewall today, I noticed at least 50 factory holes in the firewall, what are they all for? Is there a map somewhere to tell me?Tommorro I paint and the the motor goes back in for a while, and I have to hook everything up and try to fire it up.That should be interesting as I also have to change over to 12 volt.At least I feel like the "Big Giant Shelf" might actually see the road again.It sat on a farm ,dormant from 1973 till 1996.The owner gave it to his nephew who dismantled it and left it exposed to the elements after sanding it down to metal for 2 years.I bought it 2 years later for $50.00 about 10 years ago.This is the roughest body I've ever seen restored in my life. I think I paid the truck to restore it ,rather than the other way around.I had to fabricate at least a hundred panels in order to get it to this point.Every time I get to another part, I find that it too has more thru rust.I should have replaced the cab as well as every other body panel. I replaced the entire front end and box and doors.The only original body part is the parts of the cab that I didn't weld in and the front splash pan that also needed major work.Can any one relate to getting paid 3 cents an hour?But,,,,,,I am finally seeing a light,is it my old age?
Lothar, I think I once read that there are/were 74 holes in the AD firewall from the factory. Many are not used. Some are to hold the carpet/mat, some for the deluxe heater and the rest.....! That is one reason the cabs are always warm.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Socket Breaker
Socket Breaker
haha. keep at it, yer too far in to stop now!
smile
keep at it... you might end up with something like this someday:
http://www.members.shaw.ca/fatfenders/thetoad.htm
-W
