| | | Forums66 Topics128,079 Posts1,055,941 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 2 Junior Member | | Junior Member Joined: May 2006 Posts: 2 | Well here I go again with another project! This is my first time tackling a 3/4 ton though and need some help on brakes. Has anyone seen or heard of a kit to replace the drums with disc on a 68? If not, how much of a pain is it to swap to 1/2 ton spindles for the front. I can live with rear drum, but shes gonna need a complete brake system overhaul and might as well go with disc. Thanks for any help.
68 C20 Custom Camper | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I would think a 72 3/4 ton disc brake set-up would interchange. You'll have to grab the master and the prop valve too, Scott | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The spindles are probably different between the '68 and the '72. I don't know how easy it would be to swap the spindles, but the entire IFS crossmember can be swapped.
Also there is a kit to put 1/2-ton disks on a 3/4-ton. I don't remember who makes it, but pick up up one of the magazines and I bet you'll find it advertized by someone.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | After checking the Moog catalog, I think you could do the conversion just like a 1/2 ton by swapping the knuckles and balljoints. The balljoints are the same from'71-'91 so availability should be ok. The #'s are K6122(upper) and K6129T(lower). You may want to compare the parts in person to verify compatibility.
Bill Burmeister | | | | | Joined: May 2006 Posts: 2 Junior Member | | Junior Member Joined: May 2006 Posts: 2 | Looks like I have some research to do. Thanks for the info all, hope I can find the right stuff, these manual brakes lack a little to be desired. | | | | | Joined: May 2006 Posts: 5 Junior Member | | Junior Member Joined: May 2006 Posts: 5 | I have 65 C-20 that uses the 73 balljoints bolted to 73 disc spindles that I got from CPP. with upgraded power brakes and a proportioning valve and new tie-rod ends the hardest thing was getting the old balljoints out and the new ones inn. It took me about a day and a buddy to do it. Oh yeah you have to go to the 9/16's lug nuts
Fire in the hole
