| | | Forums66 Topics128,078 Posts1,055,936 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 158 | Hi, One of the last things I need for my truck is an oil bath air filter. I'm not sure which one would have been original to my truck, though! The truck is a '60 1/2 ton with the trademaster V8, 2 barrel. Do any of these look right? Exhibit A Exhibit B Exhibit C Exhibit D Exhibit E | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | A, B = no, older 6 C = maybe, can't see the height D = for bigger truck/engine I believe E = 235 one barrel it'll be similar to this one , which is 55-59, don't recall the 60's being different for the oil bath Bill | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | E was on the later 216's too.
(There's one just like it on my '49 216, and it came off of the '46 216 [AFAIK] originally.) | | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | If you're givin Exhibit C away because the answer is Exhibit E then I'll take it.  | | | | | Joined: Apr 2004 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 158 | Rattletrap, Those are all active eBay auctions currently -- none of them mine, though Brian | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | All I can say is that "E" is the same one that was on the 235 in my 61 1/2 ton 2wd. Good luck.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | |
