0 members (), 125 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
#207756 05/14/2006 7:10 AM
So, i am having BIG troubles finding the "clutch?" driver that fits in these rear fender bolts......
Anyone know where to get one?...
or tricks to get them undone?
Tony
old iron vs. new plastic....no brainer!
TECH WANTED: on S-10 frame swap
PARTS WANTED: 54 Visor, weather strips..
PARTS FOR SALE: I have complete frame / complete driveline from 54 1/2ton. very solid, will seperate
1954 GMC 3100
#207757 05/14/2006 7:16 AM
Try these: http://buy1.snapon.com/catalog/tools.asp?tool=all&Group_ID=280&store=snapon-store
You should be able to find them at your local auto parts store.
#207758 05/14/2006 7:18 AM
vice grips or grind the head of if you go to a chevy swapmeet you will find the bits
#207759 05/14/2006 10:01 AM
I just bought the 4 clutch head screwdriver set yesterday at NAPA. They aren't cheap, but they are American made and built to last. I've also seen a set listed in Chevy Duty catalog for $14.95
#207760 05/14/2006 10:54 AM
Clutch-head screws/bolt removal #1.
Clutch-head screws/bolt removal #2.
Brothers sells the rear fender clutch-head bolts in stainless steel. They also sell drivers (as do almost all repo parts dealers).
You might want to search this forum on "clutch head" for a lot of information.
#207761 05/14/2006 5:45 PM
great, so before i order it, is their any other bolts that i may run into that need a special tool?
Like the harmonic balancer, what fits that?
Tony
1954 GMC 3100
#207762 05/14/2006 7:14 PM
Gear/pulley puller. Nothing special there.
#207763 05/14/2006 7:46 PM
that will take it off, but its a weird offset i never seen befor, cant put a 3/4' socket and turn the motor with that one ............doesnt look like it anyway?
1954 GMC 3100
#207764 05/15/2006 3:47 AM
For the harmonic balancer/crank pulley- When you get the crank turned have it drilled and tapped for a regular small block chevy crank bolt- That'll make it easier for you to install and to turn over the engine with a socket during the rebuild process.
#207765 05/15/2006 4:01 AM
Quote
thats a good idea, but i want to try to turn it before i pull it out of the truck
1954 GMC 3100
#207766 05/16/2006 2:05 AM
well, i guess i'll just buy the clutch bit if theirs nothing else..
Thanks for the imformation guys smile
Tony
1954 GMC 3100
#207767 05/16/2006 3:42 PM
Screw 2 bolts into the balancer where the puller bolts would normally go then use a tire tool between them to turn it over.
Mike Barnes
1950 GMC 1-ton pickup
#207768 05/16/2006 3:44 PM
I have a snap-on clutch head socket for the fender screws.
Mike Barnes
#207769 07/31/2006 2:42 PM
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=9;t=000304#000000
www.mcmastercarr.com sells the bits you need and replacement screws. They have 3577 pages of hardware and shop related stuff and deliver quick.
Jim
Good luck with your project!
#207770 07/31/2006 7:49 PM
make sure the key is OFF when you are hand cranking it.
Another quality post.
Real Trucks Rattle
#207771 08/02/2006 3:09 AM
When putting harmonic balancer on heat in oven for 30 min at 200Degrees.Put ice on end of crank shaft for same amount of time.Lub crank with greese.Should drop right on with little hammer forse.
#207772 08/02/2006 2:30 PM
NAPA auto parts carry the clutch head drivers,also Chevy Duty,and the other mail order houses.
