0 members (), 91 guests, and 3 robots.
Topics128,095
Posts1,056,067
Members48,433
#207621 05/11/2006 8:13 PM
I'm renovating the speedometer head in my '51 pickup. Carefully removed the bezel and glass. Cleaned everything up and removed the old speedo needle, it just seemed to be pressed on to the wire shaft. Man, that's a little shaft - about .025" by the looks of it. Put one drop of light sewing machine oil down the shaft hole, and one drop on the brass sleeve that is driven by the cable.
My question is: should I take the 2 screws off the back of the head and check to see if anything needs lubricating? I've been afraid to go further, and the speedometer did work OK when I took it out. Just that the old needle was curved so badly, it dragged on the glass.
#207622 05/11/2006 10:37 PM
Fred,
did you replace the needle?....mine drags on the glass too because of being curved. I thought that maybe replacing the gasket might help, as it has gone to mush over the years.
Chuck
Blue 50
1950 3100 w/57 235
Patrick’s Saginaw 4 speed and 3:55 rear end
#207623 05/11/2006 11:15 PM
Junior Member
Junior Member
Fred;
I performed the same procedure but went ahead and removed the two screws.
The rear housing fell to the workbench before I could catch it. The housing contains a spiral spring that indexes with the speedo needle.
I guessed wrong that the needle should index after making one revolution on the spring. (A metal tab limits the range of movement)
I reassembled everything and found that the speedo now reads low.
It has to come out again and apart and the needle (i think) should be indexed on a "relaxed" spring.
It would be great if a professional Stovebolt speedo person would throw out a few words of wisdom before I tear into this again.
Mike
#207624 05/11/2006 11:49 PM
Quote
Originally posted by Blue 50:
Fred,
Chuck
I've ordered a new needle from Chevy Duty, my old one is curved and rubbing on the glass also.
(after reading what mike3100 sez, I ain't taking mine apart any further, just waiting for the new needle to show up.)
#207625 05/12/2006 12:28 PM
There was a post a long while ago by Chief that metioned this spring. I didn't go further with mine because of the spring. Mine worked correctly before and after.
1951 1 Ton Completed
#207626 05/12/2006 6:32 PM
Mine is really noisy and the needle jumps around. Then it will settle down and hold steady. I don't know if it's accurate, though. Somebody posted on here once and said they substituted a wooden tooth pick for the needle.
Professional Novice
#207627 05/12/2006 9:10 PM
Many times if the speedo is making noise and/or the needle is jumping, it is the cable becoming freyed or broken. Pull the cable out and lube it.
#207628 05/12/2006 10:17 PM
I'll try lubing the cable. Thanks wink
Professional Novice
