2 members (texczech, Peggy M), 100 guests, and 1 robot.
Topics128,136
Posts1,056,427
Members48,441
#207378 05/09/2006 12:34 AM
I have a 63 1/2 ton with original style 4 wheel drum brakes . Everything has been replaced - drums , shoes , hardware , wheel cylinders , lines and master (upgraded to a dual, non power).
I have had a squeling issue for years when braking , hence the replaced parts . The problem arises after a few miles and the brakes have warmed up . I do not want to change over to a disc system as I have invested too much money in the original drum set up . Does anyone have any ideas or suggestions about how to defeat those squealing brakes ? (no jokes about throwing out an anchor please.) Thanks in advance .
BG makes a anti-noise coating you let absorb into the shoe/pad lining that works very well. You may find something simular at a parts house to fix your noise,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
What is BG ? This anti noise coating - it isnt 10W30 is it ?
BG is BG Specialty Co. They make the cleaners for transmission flushers, anti-freeze flushers, carbon cleaners and all kinds of aerosol cleaners and lubricants. You'll probably have to go to a shop or dealership to find this brand but a lot of places carry it.
I'm not sure what's in the Brake Quiet, but you saturate the lining with it and wait until it evaporates dry, then reinstall your drums and you're done. It was developed to help eliminate noise in the high metallic pads, but does work well on shoes too.
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
Thanks AScott . I will see if I can find this in Canada . Greg.
