Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (Donf, Otto Skorzeny, Youngin' Tut 59, TooMany2count, 1 invisible), 127 guests, and 5 robots.
Topics128,277
Posts1,058,441
Members48,490
#207210 05/06/2006 11:46 PM
Junior Member
Junior Member
is this possible and any tips, is it welded in?
thanks
#207211 05/07/2006 2:33 AM
It's spot welded in, all along the windshield and cowl area. It's a structural part of the cab,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#207212 05/07/2006 6:41 PM
Junior Member
Junior Member
I don't know about the structural part because I'm new at this stuff, but I have seen them taken out. You can get a special drill bit that just drills out the spot weld, then it can be removed,repaired or replaced and then spot welded back in place.
#207213 05/07/2006 8:41 PM
Junior Member
Junior Member
thanks for the help, i was hoping it would be easier i may just leave it in then and work around it
