| | | Forums66 Topics128,275 Posts1,058,439 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 7 Junior Member | | Junior Member Joined: Apr 2006 Posts: 7 | is this possible and any tips, is it welded in?
thanks | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It's spot welded in, all along the windshield and cowl area. It's a structural part of the cab, Scott | | | | | Joined: Mar 2006 Posts: 16 Junior Member | | Junior Member Joined: Mar 2006 Posts: 16 | I don't know about the structural part because I'm new at this stuff, but I have seen them taken out. You can get a special drill bit that just drills out the spot weld, then it can be removed,repaired or replaced and then spot welded back in place. | | | | | Joined: Apr 2006 Posts: 7 Junior Member | | Junior Member Joined: Apr 2006 Posts: 7 | thanks for the help, i was hoping it would be easier i may just leave it in then and work around it | | |
