| | | Forums66 Topics128,113 Posts1,056,618 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 92 | Aftermarket hubcaps do they make them for 3/4 ton?? GMC I need a set 1947 1954 Thanks Maxx
52 GMC Grumman Olson Kurb Side stepvan T3-8(Comet)69 GMC 1/2-ton
| | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Thank God my truck had them when I bought it. They are not perfect but cleaned up nicely.
I suggest you call Jim Carter before looking elsewhere.
I've seen repros are available for Chevy but not GMC. I don't recall the supplier but I believe it was either chevy duty or bowtie bits.
I've seen some pop up at Jim Carter's on occasion in the garage sale section of the site oldchevytrucks.com
I've also seen some on occasion at Rob English's site oldgmctrucks.com, but he will take every penny you have.
And I've seen some pop up here and on ebay.
Good luck.
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Does anyone have the diameter of 3/4 ton hubcaps? I have a set, but don't know if they are 1 ton or 3/4 (if it even makes a difference). They came with my half ton. Thanks Colin | | | | | Joined: Dec 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 92 | Colin I think the two are the same. What is the price email me thanks Maxx
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The hubcap sizes are not the same as the ones for the 3/4 and 1 Ton are larger than the 1/2 Ton. | | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | 1 ton GMC had 17" rims when delivered from the factory. If your 3/4 ton has factory 17" rims the necessary hubcaps are identical to factory 1 ton GMC rims.
| | | | | Joined: Dec 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 92 | So we are saying 1 ton and 3/4 ton are not the same?
I reposted This?? What is the diameter of 3/4 ton hubcaps?? My rims are 17" 8 lug and the rear hub sticks out 3.5" Is this going to work with 3/4 caps? Thanks Maxx
