| | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | does anybody know if this rust preventer works? | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | don"t know but everyone here seems to like "zero rust" | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | counter act is one of those electric rust preventers.stick a pad at each end of your truck and wire to the control box and supposidly it will keep your truck from rusting.they were pushing it on "three guy garage" | | | | | Joined: Nov 2000 Posts: 119 Member | | Member Joined: Nov 2000 Posts: 119 | As much as I like Sam and Dave and Dave, TGG has turned into an infomercial. You have to remember that these guys also endorsed the useless Tornado gizmo that goes in the inlet air duct. They will basically shill for whatever vendor wants to buy air time. I'm pretty disappointed that they guys put their reputation on some of this stuff. Wouldn't surprise me if someone dug out some of the snake oil items from old J.C. Whitney catalogs (like the fire injection spark plugs and such) and had TGG prostitute themselves for the products.
To answer your question about Counteract, I don't see scientifically how it could work. Maybe it does, but until someone can prove it to me, my return adress is somewhere in Missouri. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Locobreath Ditto....... And if somebody wants, I Gots A Bridge fer Sale, CHEAP-HONEST :rolleyes: :p Regards | | | | | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | They use this technic on large shipps since years with succsess but you need lots a salt water to make it work. Frank | | | | | Joined: Nov 2005 Posts: 1,557 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,557 | We use it on the Trans AK pipeline but it is a much more complicated system. Anode beds and all that stuff. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
