Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
6 members (Gib70, JD1, Donf, Forty9, tclederman, 1 invisible), 520 guests, and 1 robot.
Topics126,776
Posts1,039,271
Members48,100
Most Online2,175
Jul 21st, 2025
Here's the situation. Th previous owner of my '48 half ton cut the tube from the heat gauge to the engine. I acquired a second gauge cluster with a complete heat gauge, but when I went to swap them I noticed that the replacement gauge has a longer needle and it's painted white, while the original is red. I dont see a way to change the needle, and it looks like the tube is soldered in. Is there a way to remove the tube from the one gauge and install it on the other? :confused:
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
no - called a capillary tube and has a liquid that transfer the temp info - the setup is a complete closed assembly and if the tube is cut/broken, it will never work again unless professionally rebuilt - get some of yer girls fingernail polish and paint the needle red grin
I think you can buy a replacement heat guage for about $40 from Jim Carter or Chev's of the 40s. Then you could sell the one that doesn't match on e-bay or here.
red58, that would work, except that although the part numbers match on the two gauges, the needle is significantly longer on the good gauge, and I think it's gotta be darn near impossible to shorten it. I'll probably have to go with NM51's suggestion.
Thanks to both of you.
1948 Chevy 1/2-Ton
Ex Hall Monitor
Ex Hall Monitor
Check Hemmings Motor News. There are a number of shops that repair gauges and advertise there.
www.hemmings.com
Thanks, Tiny. I checked Hemmings, but didn't see any gauge rebuilders or restorers there. What category were they under?
1948 Chevy 1/2-Ton
Watch E-Bay "53 chevy parts and accesories" but I must warn you it's addictive, I spend an hour + a day
Your tools are picked up and played with,what is called a shop Grimlin. These verry fast small furry animals with big ears and large eyes will return what ever they have taken when they get done exporing and playing with it.When one has my tool I just go to another task and before you know it he's done with it and has returned it.Only caught a glimpse of him one time.They hang out anywhere work is going on.
Beaver, I have a "48 Chevy Truck" search and you're right. I can spend a long time on there.
1948 Chevy 1/2-Ton
D&M Restorations in Greenville S.C. can fix your capillary tube. Diane and Mike are nice folks and do very good work. Did all my guages on my 37 and lots of guages for friends around this area. 1-800-722-0854 or 864-421-9959
Ex Hall Monitor
Ex Hall Monitor
Quote
Do a "keyword" search for "gauge repair". I did & it turned up 70+ hits. Most weren't applicable but I saw several that might fit the bill. You just have to scroll through them.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.099s Queries: 13 (0.096s) Memory: 0.6395 MB (Peak: 0.7259 MB) Data Comp: Zlib Server Time: 2025-09-22 14:58:45 UTC
Valid HTML 5 and Valid CSS
