9 members (Wickedbass, Donf, TexasJim50, treegrower, sron48, Bill Hanlon, rfs56trk, Hanks custodian, Wally / Montana),
49
Mod | | | Forums66 Topics128,075 Posts1,055,916 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2002 Posts: 102 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 102 | A friend of mine called me today with a truck question I couldn't answer. He said, someone knowing he was a car guy, told him about a 53 GMC truck for sell with a factory automatic transmission. I wasn't sure of the first year of the hydromatic in an AD truck. Can someone tell me? Thanks.
Ron Thompson 51 Chevy 1/2 ton 36 F@rd coupe 65 Riviera
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Ron, I have a factory 53 G.M.C. 3/4 ton 228/hydramatic, hope that helps. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | 1953 was the first year. Chevy offered it in 1954. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | how many speeds does it have? -W | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | 4 but first gear just gets the truck moving. Supposed to have 100% efficiency like a manual. Modern auto trans have almost 10% slippage. | | | | | Joined: Jan 2006 Posts: 21 Junior Member | | Junior Member Joined: Jan 2006 Posts: 21 | 53 gimmi hydra was 2 speed, I believe.
Taco
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | 4 speed: the gear selector has 1-2 1-3 1-4 so you really can't hold it down in 1 (low)
Professional Novice
| | | | | Joined: Jan 2006 Posts: 21 Junior Member | | Junior Member Joined: Jan 2006 Posts: 21 | Ur right Frank-- I'm mstaken the post 64 turbo hydramatic was 2 speed the 1953 was a 4 speed. My goof.
Taco
