6 members (treegrower, bobfake, J Lucas, Jeff Ogden, Wickedbass, DoubleB), 58 guests, and 2 robots.
Topics128,091
Posts1,056,033
Members48,433
#206122 04/17/2006 9:30 PM
OK, I have a 39 GMC 1/2 ton which uses a 40 bed. The original bed had a metal floor but now I will be using a wood floor bed.
Any body know the thickness of the mounting blocks? Need thickness for the fronts, middles and rears. THANKS
ttt
Nobody knows the stock height of the blocks for a 40 chev?
stea, Put this request in the forum for "making a stovebolt bed" and I am sure someone will get the answer. If they are the same as a 37 I could measure mine....OR if you have the packet from Chevy Assistance look at the measurements for he cab/bed alignement and you may be able to figure it out?
#206125 04/18/2006 10:53 PM
I don't know myself, but second the suggestion that you post this into the 'making a bed' forum.
Also, if the factory assembly manual is available you could get the data from that. Possibly the Restoration Pack from GM would tell you. There is an online forum that has lots of manuals in PDF format, which might be helpful too.
http://chevy.tocmp.com/index.htm
Here's a Master Part's catelog from '29-'54, which might have what you need:
http://chevy.tocmp.com/1929_54chevyparts/index.htm
Here's a link to a page of resources that might put you in the right direction.
http://chevy.tocmp.com/chevyresources.htm
#206126 04/18/2006 10:57 PM
Found you the restoration pack on-line too.
http://chevy.tocmp.com/chevyresto/39index.htm
Go to "Tech Tips" here on the Stovebolt (very top of the page), and look for "1936-'46 bed mounting blocks", that may help you.
To be long remembered as he's cruising in
The Passing Lane
I measured the blocks under my '40 GMC bed. There are 3 on each side. The front and rear blocks are 1-7/8" and the middle blocks are 1.5".
Steve
See my 1940 Canadian GMC:
http://community.webshots.com/user/ndnchf
Should have looked in the tech tips section first, thanks for the reminder Barry.
Looks like the fronts are 2" the middles are 2" and the rears are 4" Looks like I will have to make adjustments on the rears though. I want a hidden bolt setup.
ndnchf- Do you have the metal floor or a wood floor?
Mine is a long, wood bed. The crossmembers at front and rear are wood. The middle crossmember is steel and a little taller than the wooden ones. Thats why the middle block is a little smaller. You can see photos in my webshots page.
