| | | Forums66 Topics128,069 Posts1,055,884 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | OK, I have a 39 GMC 1/2 ton which uses a 40 bed. The original bed had a metal floor but now I will be using a wood floor bed.
Any body know the thickness of the mounting blocks? Need thickness for the fronts, middles and rears. THANKS | | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | ttt
Nobody knows the stock height of the blocks for a 40 chev? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | stea, Put this request in the forum for "making a stovebolt bed" and I am sure someone will get the answer. If they are the same as a 37 I could measure mine....OR if you have the packet from Chevy Assistance look at the measurements for he cab/bed alignement and you may be able to figure it out? | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I don't know myself, but second the suggestion that you post this into the 'making a bed' forum. Also, if the factory assembly manual is available you could get the data from that. Possibly the Restoration Pack from GM would tell you. There is an online forum that has lots of manuals in PDF format, which might be helpful too. http://chevy.tocmp.com/index.htm Here's a Master Part's catelog from '29-'54, which might have what you need: http://chevy.tocmp.com/1929_54chevyparts/index.htm Here's a link to a page of resources that might put you in the right direction. http://chevy.tocmp.com/chevyresources.htm
| | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Go to "Tech Tips" here on the Stovebolt (very top of the page), and look for "1936-'46 bed mounting blocks", that may help you. | | | | | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | I measured the blocks under my '40 GMC bed. There are 3 on each side. The front and rear blocks are 1-7/8" and the middle blocks are 1.5".
Steve | | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | Should have looked in the tech tips section first, thanks for the reminder Barry.
Looks like the fronts are 2" the middles are 2" and the rears are 4" Looks like I will have to make adjustments on the rears though. I want a hidden bolt setup.
ndnchf- Do you have the metal floor or a wood floor? | | | | | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | Mine is a long, wood bed. The crossmembers at front and rear are wood. The middle crossmember is steel and a little taller than the wooden ones. Thats why the middle block is a little smaller. You can see photos in my webshots page. | | |
