0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 87 | anybody recomend the disc conversion kits ? do these trucks drive ok even on freeway with a standard front end but added discs or should i just add a modern clip even better anybody know a way to add discs and get a 5 bolt common bolt pattern without buying a kit???? i would be suprised if theres not a simple way using bonyard bits and maybe mix/matching bearings?? | | | | | Joined: Oct 2003 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 90 | rusthater, I'm lookin at my Classic Performance Products catalogue. They have a 5 lug disc bracket kit for your truck for 95.00 You can check it out at- www.classicperform.com | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The problem with a junk yard disk conversion is that you have to fabricate the caliper bracket. For some guys thats a trivial task, but for most its not worth saving the $100 a kit cost.
My '55 1st GMC runs down a smooth freeway real nice with a stock front axle running a disk kit. I need kingpins, tie-rod ends and maybe an alignment, so running down a bumpy road its a little more work.
If your only reason to change is disk brakes I'd suggest rebuilding your stock front before looking at the IFS options.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | The conversion involves at a minimum:
Caliper bracket calipers & pads flexible brake lines rotors
I'm I belive you can do the conversion without changing the bearings but I think it is a good time to change them.
You don't have to do any work on the rest of the suspension or steering components to switch to disc brakes, but you probably should at least check them to make sure they don't need it because when you do the conversion it is easy to the do the rest of it.
One thing to think about is whether you plan on doing anything to the rear axel. If not, you might want to get a 6 lug conversion rather than 5 lug, that way you can use the same rims. Some vendors sell the 6 lug conversion kits or you can buy just the rotors and brackets and then get some calipers, pads, bearings and hoses from a FLAPS.
| | | | | Joined: Jan 2004 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2004 Posts: 70 | I belive they say the stock brake master cylinder has to be replaced also, the price really starts to add up. They also recommend roller bearings instead of the round bearings if you are using power steering. I think if you were going to do a lot of highway driving and like to go 70 mph, I would go with the clip. Otherwise, just do the disc conversion. I'm really happy with the way they stop, and it's one less thing to worry about. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I drive mine on the hi-way at 60 plus and have no problem,, lowered, and stock front axle,,stock brakes.......... well the rear brakes are'nt stock as I have a blazer rear end,, a little larger drum brakes but still all stock stuff.
a lot of folks want to up grade though so.......I am ok with what I have. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2006 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 67 | That you Wayne? Funny, we live about 10-15 milea apart and end up talking on a forumin the US LMFAO!!
I'll bring my truck round one night in the week, we can have a look together and see what we can come up with.
Do we have to drink Budweiser now we have pick-ups? | | | | | Joined: Feb 2006 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 67 | Oh yeah, my number is lower than your number.... | | | | | Joined: Apr 2006 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 87 | hi taff lol yeah sure cmon over | | | | | Joined: Apr 2006 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 87 | joker sounds ideal any chance of a picture of your truck i want mine lowered but with better brakes.ive heard from a few people here they dont drop too well on a std front end??
shoe. i would probably just bolt up a bulkhead booster/cylinder
nm51 thanks for the info but what are flaps? (yes i know your laughing taff)
oldsub i could make the bracket easy enough if somebody can post a acurate picture
resto44 cheers just looked at that site some of there stuff is a little more expensive but it does tell me wich discs(rotors) and calipers to get here.
everybody the thing is over here most people simply swap in a jaguar front clip wich adds a whole bunch of upgrades all in one and there cheap and easy to do the problem/expence comes from either converting to right hand drive (the cab) or finding/fitting a lhd stering rack also thers a lot of talk about law changes here wich may render the clip swap a bad idea as it could present problems with registering/licencing but its not law yet! so its a choice/gamble that needs to be made thanks everyone | | |
