1 members (UtahYork), 76 guests, and 1 robot.
Topics128,049
Posts1,055,740
#205610 04/08/2006 12:45 AM
Apprentice
Apprentice
I just bought a 53 6500 and I can't remove the panels in the cab because the bolts are a type I have never seen before. If anybody can tell me what kind of tool I need to order and where I can get, if there even is one, that would be great.
#205611 04/08/2006 12:57 AM
welcome to the garage N. - you've found the right place for that particular problem - it's a standard old GM fastener called clutch head - most vendors have the screwdrivers/bits, including NAPA and Snap-on
#205612 04/08/2006 1:10 AM
Welcome aboard!
#205613 04/08/2006 1:14 AM
Apprentice
Apprentice
Thanks I'll check it out.
#205614 04/08/2006 1:56 AM
Whereabouts in Minnesota are you?
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
#205615 04/08/2006 2:59 AM
By the way those things are hardened, don't bother trying to drill them out. Check out the Tech Tip on Clutch Head Bolts
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#205616 04/08/2006 7:18 AM
But, heating them up with a torch will loosen the rust bond and make them much easier to remove.
#205617 04/08/2006 3:36 PM
Apprentice
Apprentice
Thanks everyone, also I found out that the engine is shot, and I have a 350 SBC that would bolt up to the trans. Anyone have any advice?
