2 members (KEVINSKI, 55shaker),
125
Mod | | | Forums66 Topics128,187 Posts1,057,313 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 8 Junior Member | | Junior Member Joined: May 2004 Posts: 8 | Hi everybody can I get some help in finding the vin # on this chevy truck? Thanxs for looking,stefanP
"Rust Never sleeps"
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Vin plate for 38 1.5 will be located under the passenger side hood on side of cowl as opposed to the front of cowl on the 41 thru 47 1st series. should be 2 tags there. Will be between front of cowl and braided welt? cushion? | | | | | Joined: May 2004 Posts: 8 Junior Member | | Junior Member Joined: May 2004 Posts: 8 | kb3csw ,thanxs for the responce.I haven't found anything like you said.Guess I'll have to look harder. stefanP
"Rust Never sleeps"
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Just went out and looked at my 38. Perhaps my terminology was wrong. When you lift the passenger side hood the vin tags are located on the side of cab under the hood between the firewall and the weather stripping. there are two tags one with vin and one with weight capacity. the top tag is about 2"X6" with vin. the bottom tag has capacity info about 1.5"X6" both tags are mounted so long side is vertical. If you have 4 (2 each Plate) screw holes or screws holding nothing in these positions the vin tags may have been removed. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Your "serial number" is on the plate kb3csw refers to. Your "Vin" is the engine number which is on a milled boss just behind and below the distributor. I had to scrape 1/4" of gunk off of mine to get the number. If you request the Restoration Packet from Chevrolet the engine number is the number they will ask for. That is the number your title is issued to. You can request a Restoration Packet by calling 1-800-222-1020. It has all of the info about your truck that the factory has. All the specs and info like where your numbers are (page 9).
| | | | | Joined: Mar 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 113 | Tiny - I'm curious about the Restoration Packet you mention. What is it?
I have a '37 that is missing the cab plates altogether (it took photos of other trucks to show me where they used to reside). I found the chassis numbers while prepping for the IFS I installed.
Once it's gone I don't suppose there's any way to figure out exactly what you have...
Everything is different now...
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | They photo copy all of the specs for your year vehicle, cars, truck, taxis, etc.. It has engine specs, tranny, frame, rearend, body, suspension specs. It tells you how to decode the numbers, how to figure engine speed in different gears at different highway speeds. It's basically all of the technical info they have on your year vehicle. It includes diagrams a drawings. It's free to US citizens. Well worth a phone call. They will ask for your VIN "engine" number.
