1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 40 Member | | Member Joined: Aug 2005 Posts: 40 | I've been away from the forums for a bit. It's been very busy at work, mainly, so I haven't had time to check in as often as I'd like.
As a result of the insanity at work, I decided to take my one free weekend and get the heck out of town and shut off my phone for a weekend. The li'l woman and I went to her hometown and decided to examine the '54 while we were there. I extracted the VIN and poked under the hood and do some exploring.
Man, is she in rough shape. From the outside, it looks alot more solid. The typical areas where you'd expect some serious rot are rotted like the cab corners and some other places where water could pool. The inner fenders will need replacing. My concern is the seam where the upper portion of the cab meets the lower portion of the cab. Am I correct in understanding that if that seam is rotting, then the entire cab is useless?
At one point one owner flipped the rear axle on top of the leaf springs for a low stance. There's rotted shock mounts and such, but the frame itself looks intact and solid, but I won't know for certain until we get into some disassembly and cleanup.
I've got some photos and will post them here when I get them offloaded later this week. Tilt your head back, cuz Mama Bird is going to ram a juicy nightcrawler of truth down your throat! | | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | Welcome back. I can't help with the cab question but sure someone here will chime in.
Post those pics as soon as you can, we would like to see them. | | | | | Joined: Aug 2005 Posts: 40 Member | | Member Joined: Aug 2005 Posts: 40 | Not really a question so much as a statement of where I'm at and what I've discovered. Tilt your head back, cuz Mama Bird is going to ram a juicy nightcrawler of truth down your throat! | | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | I'm of the mind that as far as sheet metal goes any damage can be fixed by welding in new metal. It just takes time and patients and of course the propper tools. If there is a better cab available that would be a lot faster, easier, and possibly cheaper depending on the price of the cab and whether you are doing the work yourself or farming it out.
Jim
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Kinda sounds like with your work load you should look for a truck in better condition. | | | | | Joined: Sep 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 310 | No he shouldn't, the truck keeps him going, it's "quality" time and once finished almost a family member. You got to have something else besides work. | | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | John ...WE Missed you man Now how about another day of walking around a swap meet, and watching you de-bugg some computer system in Toledo.  "that takes talent" Cliff59 | | |
