0 members (), 54 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#204711 03/26/2006 7:31 PM
Another Question,any one know if a vacuum reservoir ever used on an AD.If not has any one of you guys tried one,and does it work.
Thanks Don
Mr.Giant
1953 Chevrolet 3100 in the Gallery
1959 GMC 860 Single Axle Truck Tractor in the Gallery
#204712 03/26/2006 8:13 PM
Junior Member
Junior Member
I made one one time out of a small air tank and used a check valve. It helped a little but not on long hills.
If you are going to keep the truck spend the money on electric and you will be very happy.
Chevy Duty has the best price.
Paul
When you do a good deed, get a receipt just incase HEAVEN is
like....the IRS
#204713 03/26/2006 11:46 PM
just put a dual action fuel pump on and had my wipers overhauled and i am more than happy. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#204714 03/27/2006 12:09 AM
Thanks, Ron,There is a dual action fuel pump on now,how does that work,is there another vaccum line from the fuel pump?
Don
Mr.Giant
#204715 03/27/2006 12:27 AM
V
V Offline
I've got one of those but it hsn't been installed yet. I believe there are two lines from that duel action pump.
#204716 03/27/2006 3:38 AM
Here's a thread on the dual action pump.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=003936
Fred
52 3600
69 C-10
#204717 03/27/2006 5:08 AM
Thanks Fred and all the other guys,It has made it clear I know what I have to do now.
Thanks again. DON
Mr.Giant
#204718 03/27/2006 1:42 PM
Is there a good way to test the wiper vacuum motor to know it is good before it is installed. Has anyone seen rebuild kits for these?
Jim
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#204719 03/27/2006 5:42 PM
Jim and all
Down here 5 minutes from me in West Babylon,Rob Ficken,Fickens wiper service
http://www.wiperman.com
Quality work and the right price,doesnt pay to mess around wink
PS on his site he tells how to quickly diagnose the wiper motor
#204720 03/27/2006 6:18 PM
I'm with stevesr, Ficken did a great job on my wiper motor, works great, quick and no hastle.
1946 1/2-Ton Chevy
#204721 03/27/2006 6:37 PM
Quote
Jim
You can hook it up to a running engine. A quick check is to blow into the motor, it doesn't take much pressure to check for a leaky diaphragm. (Years ago I learned not to suck on old parts, no telling what you will suck into your mouth!)
Biggest problem with the older motors is the grease on the diaphragm gets hard. The motor works, but runs slow, especially when cold. Spraying oil on the diaphragm can help soften the grease. If you're careful, you can take the motor apart without tearing the diaphragm. Clean off the old grease and apply new.
Rebuild kits are available, but haven't been mass-produced in years. I would assume that the motor rebuilders are making their own diaphragms.
Fred
52 3600
69 C-10
#204722 04/05/2006 11:25 AM
V
V Offline
Steve and All,
Thanks for the link and info!
#204723 04/05/2006 2:56 PM
I used a coffee can w/ two small tubes soldered into it
Jim & Caroline
