0 members (),
200
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | Another Question,any one know if a vacuum reservoir ever used on an AD.If not has any one of you guys tried one,and does it work.
Thanks Don | | | | | Joined: Jul 2004 Posts: 39 Junior Member | | Junior Member Joined: Jul 2004 Posts: 39 | I made one one time out of a small air tank and used a check valve. It helped a little but not on long hills. If you are going to keep the truck spend the money on electric and you will be very happy. Chevy Duty has the best price.
Paul
When you do a good deed, get a receipt just incase HEAVEN is like....the IRS
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | just put a dual action fuel pump on and had my wipers overhauled and i am more than happy. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | Thanks, Ron,There is a dual action fuel pump on now,how does that work,is there another vaccum line from the fuel pump?
Don | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I've got one of those but it hsn't been installed yet. I believe there are two lines from that duel action pump. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Here's a thread on the dual action pump. http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=003936
Fred 52 3600 69 C-10
| | | | | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | Thanks Fred and all the other guys,It has made it clear I know what I have to do now. Thanks again. DON | | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Is there a good way to test the wiper vacuum motor to know it is good before it is installed. Has anyone seen rebuild kits for these?
Jim
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
| | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Jim and all Down here 5 minutes from me in West Babylon,Rob Ficken,Fickens wiper service http://www.wiperman.com Quality work and the right price,doesnt pay to mess around PS on his site he tells how to quickly diagnose the wiper motor | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I'm with stevesr, Ficken did a great job on my wiper motor, works great, quick and no hastle. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Originally posted by cujo8: Is there a good way to test the wiper vacuum motor to know it is good before it is installed. Has anyone seen rebuild kits for these?
Jim You can hook it up to a running engine. A quick check is to blow into the motor, it doesn't take much pressure to check for a leaky diaphragm. (Years ago I learned not to suck on old parts, no telling what you will suck into your mouth!) Biggest problem with the older motors is the grease on the diaphragm gets hard. The motor works, but runs slow, especially when cold. Spraying oil on the diaphragm can help soften the grease. If you're careful, you can take the motor apart without tearing the diaphragm. Clean off the old grease and apply new. Rebuild kits are available, but haven't been mass-produced in years. I would assume that the motor rebuilders are making their own diaphragms.
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Steve and All,
Thanks for the link and info! | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | I used a coffee can w/ two small tubes soldered into it
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
