4 members (classicfins, msmall, Shaffer's1950, Gray_Ghost), 96 guests, and 1 robot.
Topics128,108
Posts1,056,568
Members48,448
#20454 05/10/2005 7:11 PM
Junior Member
Junior Member
I'm looking to put disc brakes on the rear instead of using the original drums. Is there a simple (and cheap) way to put discs on the rear end or will I need to swap out the rear end? And if I go about swapping out the rear end does anyone know of one with a similar width and has disc brakes. Oh, this is a 1/2 ton if it makes any difference.
-- Ryan James
#20455 05/10/2005 9:01 PM
Riding in the Passing Lane
The simple way is to buy a kit from one of the specialtie suplyers but it,s not cheap anyway you go.
1972 Chevy c10 Cheyenne Super
#20456 05/10/2005 10:13 PM
If you want to keep it 6 lug you can get a '63-'67 rear axle out of a 1/2 ton Chevy truck. If you get the right one you can get a 3.07 rearend. There is a cheap disc brake kit for that axle.
Paint & Body Shop moderator
#20457 05/11/2005 4:28 AM
Where could I find the cheap disc kit for the 63-67 rear axle?? Have one under my 46 half ton.
1946 1/2-Ton Chevy
#20458 05/11/2005 5:08 AM
Junior Member
Junior Member
Yeah if you've got a link or manufacturer name that'd be useful as I've spent the last hour trying to find it and have so far been w/o luck.
Thanks in advance.
#20459 05/12/2005 2:39 AM
What about the disc brake rear end from a 1999-2005 Chev/GMC 1/2 ton? They have the same 6-bolt pattern as the early trucks. Or the width of the 6-bolt disc brake axle from a late model Chev Trailblazer/GMC Envoy might work better for you.
