7 members (Shade Baby, Lightholder's Dad, DoubleB, Oswald, Sjm, Phak1, 1 invisible),
131
Mod | | | Forums66 Topics128,271 Posts1,058,417 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20454 05/10/2005 7:11 PM | Joined: Apr 2005 Posts: 11 Junior Member | | Junior Member Joined: Apr 2005 Posts: 11 | I'm looking to put disc brakes on the rear instead of using the original drums. Is there a simple (and cheap) way to put discs on the rear end or will I need to swap out the rear end? And if I go about swapping out the rear end does anyone know of one with a similar width and has disc brakes. Oh, this is a 1/2 ton if it makes any difference.
-- Ryan James | | |
#20455 05/10/2005 9:01 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The simple way is to buy a kit from one of the specialtie suplyers but it,s not cheap anyway you go. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#20456 05/10/2005 10:13 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If you want to keep it 6 lug you can get a '63-'67 rear axle out of a 1/2 ton Chevy truck. If you get the right one you can get a 3.07 rearend. There is a cheap disc brake kit for that axle.
#20457 05/11/2005 4:28 AM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Where could I find the cheap disc kit for the 63-67 rear axle?? Have one under my 46 half ton. | | |
#20458 05/11/2005 5:08 AM | Joined: Apr 2005 Posts: 11 Junior Member | | Junior Member Joined: Apr 2005 Posts: 11 | Yeah if you've got a link or manufacturer name that'd be useful as I've spent the last hour trying to find it and have so far been w/o luck.
Thanks in advance. | | |
#20459 05/12/2005 2:39 AM | Joined: Nov 2002 Posts: 59 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Nov 2002 Posts: 59 | What about the disc brake rear end from a 1999-2005 Chev/GMC 1/2 ton? They have the same 6-bolt pattern as the early trucks. Or the width of the 6-bolt disc brake axle from a late model Chev Trailblazer/GMC Envoy might work better for you. | | |
