8 members (Donf, Goach2, Otto Skorzeny, cmayna, Joe H, Wally / Montana, Gdads51, 1 invisible), 89 guests, and 0 robots.
Topics128,118
Posts1,056,307
Members48,439
J Online: Content
That thing would work great if you wanted the exhaust to exit out the front fender! eek Joe
Aw, come on Joe. A couple elbows and a hole saw and you could run 'em right up through the hood.
To be long remembered as he's cruising in
The Passing Lane
Kip Offline
Hey! Those would work great on a hot rod..........irrigation motor!
Adios, Kip
Write On The Cross At The Head Of My Grave
To Whiskey And Women Here Lies A Poor Slave
"Mommy ! Take the bad pictures away, please !
They're scaring me !"
Yipe!
Boy, just think of all the things I could "create", if only I knew how to weld... wink
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
Has Oly been playing with his welder again eek :p
This guy getting around my truck is going to have a welding rod where it will make it hard to walk eek
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2417588885&category=33632
Both are fine example of why stupid people should not be allowed to weld. If I asked a guy to split the manifolds on one of my trucks, and he did a job like that, he would be a grease spot on the concrete. I.E. make sure his [censored] is thoroughly, and efficiently kicked! :mad:
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht-
Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
re: reply from Barry Weeks.....with a couple of extra elbows the exhaust could be routed through the cab!!!
Sure to give you that dizzy feeling within 30 seconds?
The Passing Lane
Y
Y Offline
You could use that to mount a stovebolt in a motorcycle frame. grin
1954 Chevy 3100 235
2 Yamaha YSR50's
05 Silverado crew
00 Yamaha TT-R125 Supermoto
Or a wood & canvas bi-plane !
Frank McMullen
It would work very well in a boat, some of which use 250's and 292's.
Paint & Body Shop moderator
