1 members (chemanic),
87
Mod | | | Forums66 Topics128,134 Posts1,056,416 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20421 05/31/2003 1:33 AM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | | | |
#20422 05/31/2003 4:45 AM | Joined: Feb 2000 Posts: 5,223 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,223 | That thing would work great if you wanted the exhaust to exit out the front fender!  Joe | | |
#20423 05/31/2003 1:49 PM | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Aw, come on Joe. A couple elbows and a hole saw and you could run 'em right up through the hood. | | |
#20424 05/31/2003 2:46 PM | Joined: Feb 2000 Posts: 177 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 177 | Hey! Those would work great on a hot rod..........irrigation motor! Adios, Kip
Write On The Cross At The Head Of My Grave To Whiskey And Women Here Lies A Poor Slave
#20425 05/31/2003 3:59 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | "Mommy ! Take the bad pictures away, please ! They're scaring me !" Yipe! Boy, just think of all the things I could "create", if only I knew how to weld...
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
#20426 05/31/2003 4:29 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Has Oly been playing with his welder again  :p
#20427 05/31/2003 5:36 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | This guy getting around my truck is going to have a welding rod where it will make it hard to walk http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2417588885&category=33632
#20428 05/31/2003 9:30 PM | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 | Both are fine example of why stupid people should not be allowed to weld. If I asked a guy to split the manifolds on one of my trucks, and he did a job like that, he would be a grease spot on the concrete. I.E. make sure his [censored] is thoroughly, and efficiently kicked! :mad:
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht- Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
#20429 06/01/2003 2:04 AM | Joined: Mar 2003 Posts: 93 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 93 | re: reply from Barry Weeks.....with a couple of extra elbows the exhaust could be routed through the cab!!! | | |
#20430 06/01/2003 3:48 AM | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Sure to give you that dizzy feeling within 30 seconds? | | |
#20431 06/01/2003 4:58 AM | Joined: May 2003 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 27 | You could use that to mount a stovebolt in a motorcycle frame.
1954 Chevy 3100 235 2 Yamaha YSR50's 05 Silverado crew 00 Yamaha TT-R125 Supermoto
#20432 06/01/2003 2:49 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Or a wood & canvas bi-plane !
#20433 06/02/2003 10:54 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | It would work very well in a boat, some of which use 250's and 292's.
