| | | Forums66 Topics128,012 Posts1,055,321 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 70 Member | | Member Joined: Feb 2006 Posts: 70 | how do you polorize a generator
bill
| | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | http://web.utk.edu/~tprather/FoothillsTractorClub/TechTips/PolarizeGenerator.html
All you need to know.
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
bill
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | So any time you unhook the generator you need to do this?
Thanks, jeff | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Originally posted by rustednuts: So any time you unhook the generator you need to do this?
Thanks, jeff Usually, you have to do it only if you jar it really hard when you have it off of the engine, or it's been off for a really long time. I didn't repolarize mine when I cleaned it up, and it works like a champ. | | |
