3 members (Bill Hanlon, FishinToms53, tesa), 110 guests, and 2 robots.
Topics128,087
Posts1,056,000
Members48,430
#203771 03/14/2006 11:10 PM
Is an overdrive from a '57 Chevy car the same as an overdrive from a '55 Chevy Pickup? What is this transmission worth?
They can be, but I have heard that the truck ones have more splines on the shafts. They go from 100-150 depending on how well they work and if all the bits are there.
#203773 03/15/2006 11:57 AM
ODSS President
ODSS President
Double that ($) for a rebuild and then there's the "ebay factor". Same amount of splines. These Borg-Warner transmissions have a .70 overdrive gear resulting in this formulation for my final drive .70 X 3.90 ('57 open rear differential) = 2.73.
Perfect gearing for highway speed and fuel economy. I have had this transmission installed in this configuration on my '49 1/2 ton now for 6 years+.
~ Cosmo
1949 Chevy Half Ton
#203774 03/16/2006 10:21 PM
There is no difference internally. The only difference is in the mounting to the bellhousing. The car trans has 4 open holes in which the bolts are threaded into the bellhousing. The truck has the lower holes on the trans threaded and the bolts are installed from inside the bellhousing into the trans. It is easy to work around these differences. The transmission case and gears are essentially the same as a standard muncie car or truck 3 speed.
#203775 03/16/2006 10:32 PM
The side cover and levers that operate the shifting forks may be different but I believe that can be overcome by using the side cover from your old tranny.
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
