3 members (WICruiser, 2 invisible),
142
Mod | | | Forums66 Topics128,109 Posts1,056,269 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 63 | I am new at this but I am trying to take off my 1952 running boards and the bolt spins. I can not reach behind the bolt. I tried a cutoff wheel on my dremel but the disk is too wide for the channel the bolt sits in. A hacksaw blade is taking forever to take the threaded end off so I could drill it out. Any suggestions to a newbe at this. Thanks, Wayne | | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | Hammer and chiesel, cutting torch or even try just wacking it from side to side till it breaks off.
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | It's a square nut I believe that sits up in a slot in the running board, As soon as you try to turn it, the square nut just spins in the slot as the metal from the tab that holds the nut in place just bends. Like highwayman says just break them and get replacement nuts and screws from the local hardware store. Bob T | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | One of those small air disc cutters with a 2 or 3" blade should be able to cut the bolt at bottom side. Just don't cut metal or not much anyway. OR, I use a 4-1/2" grinder many times. Did you try to pull up on step to lock heads in better? If they are tight, better to just tighten more till they break off. They are pretty small bolts, break easy.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Most of the time, I lock some vise-grips on the rusted nut as tight as possible. Then "wag" it back and forth until it snaps off. | | | | | Joined: Mar 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 63 | Thanks everybody. I appreciate the help!! Wayne | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | what mns smith said works the best and fastest | | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | MNSmith has the best idea I have taken off several sets of running boards,vise grips back and forth to break the bolts is quick and painless. | | |
