5 members (Otto Skorzeny, Hotrod Lincoln, jay d, ‘37ChevyPU, Bill Hanlon), 175 guests, and 1 robot.
Topics128,109
Posts1,056,262
Members48,439
#203545 03/11/2006 8:26 PM
Z
ZB3
Offline
Z Offline
I am new at this but I am trying to take off my 1952 running boards and the bolt spins. I can not reach behind the bolt. I tried a cutoff wheel on my dremel but the disk is too wide for the channel the bolt sits in. A hacksaw blade is taking forever to take the threaded end off so I could drill it out. Any suggestions to a newbe at this. Thanks, Wayne
Hammer and chiesel, cutting torch or even try just wacking it from side to side till it breaks off.
38 original
48 panel
59 stepside
46 in the back forty
#203547 03/11/2006 10:43 PM
It's a square nut I believe that sits up in a slot in the running board, As soon as you try to turn it, the square nut just spins in the slot as the metal from the tab that holds the nut in place just bends. Like highwayman says just break them and get replacement nuts and screws from the local hardware store.
Bob T
#203548 03/11/2006 10:51 PM
One of those small air disc cutters with a 2 or 3" blade should be able to cut the bolt at bottom side. Just don't cut metal or not much anyway. OR, I use a 4-1/2" grinder many times.
Did you try to pull up on step to lock heads in better? If they are tight, better to just tighten more till they break off. They are pretty small bolts, break easy.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#203549 03/11/2006 11:05 PM
Most of the time, I lock some vise-grips on the rusted nut as tight as possible. Then "wag" it back and forth until it snaps off.
#203550 03/11/2006 11:26 PM
Z
ZB3
Offline
Z Offline
Thanks everybody. I appreciate the help!! Wayne
what mns smith said works the best and fastest
MNSmith has the best idea I have taken off several sets of running boards,vise grips
back and forth to break the bolts is quick and painless.
