2 members (3B, baldeagle), 105 guests, and 7 robots.
Topics128,014
Posts1,055,328
Members48,419
#203337 03/10/2006 4:43 AM
I just replaced one of my taillights on my '66 C-10 stepside. It works fine except that when the brakes are on and the turn signal is on, it won't blink from high to low, instead it blinks on and off. Also, when the headlights are on and I press the brake pedal, it cuts off, and when the headlights are on and the turn signal is on, it blinks on and off, not high to low like the old one did. What's going on with it and what can I do to fix it? Any help is much appreciated.
Drew
'66 C-10 stepside
#203338 03/10/2006 4:47 AM
Sounds like a poor ground. I ran a ground wire right to the backside of the tail housing instead of relying on the body ground. Never had a problem since,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#203339 03/10/2006 5:08 AM
It is supposed to blink on to off. With a tail light on it might appear to be high to low but it would really be the tail light filament is lit when the turn filament is going on to off.
