| | | Forums66 Topics128,095 Posts1,056,468 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | When I push the brake pedal to stop, the truck pulls hard to the right. If you don't have your hand on the wheel the truck will literally end up in the ditch!!!
I know very little about brakes so any help would be appreciated. The truck is a '54 3600.
Thanks!
Steve
Today is the best day of my life!!!
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | A leaking wheel cyl. will put oil on the linings making them worthless. pull the front? drum and inspect the linings. replace the wheel cyl befor you re line the brakes or you will gain nothing | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is probably grease or brake fluid leaking on the right front brake. Someone needs to pull the front drums & inspect the brakes. Other possibilities are stuck wheel cyl. pistons or swollen brake hoses. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2005 Posts: 4,256 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,256 | Start at the beginning! Pull both front drums and have a look. Besides the previous ideas, it could be that the right front is working fine but the left isn't working at all! Pull both fronts and have a look. Either have somebody experienced do it or report back here what you find and we can proceed from there. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Your truck is a republican. How severe it moves right will determine if it is a compassionate conservative or a far right winger. Remember though it is better to swerve away from on coming traffic than into it, in most cases. Wheel cylinder would be my first suspect, followed by a mechanical issue inside the drum. | | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | My '54 3100 had exactly the same problem. After a complete brake rebuild (my first and it turned out fine - which means any goof can do it) the problem was solved. Everything was rebuilt - wheel cylinders, new shoes, new springs. Good luck! If you are interested in working on it yourself, I'd recommend a Haynes manual. You can pick one up at Barnes & Noble. Mine is for mid-seventies to late eighties Chevy trucks. The brakes on my '54 were exactly like the ones in the book. I looked at the pictures, followed the instructions, and got it done.  | | | | | Joined: Jan 2006 Posts: 74 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 74 | if your gonna replace the wheel cylinder replace them all and the brake shoes and lines if they are old and you will be happy with the results | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | I had the same problem. Turns out it was sezied wheel cylinder. Good luck. Colin | | | | | Joined: Jul 2005 Posts: 34 Apprentice | | Apprentice Joined: Jul 2005 Posts: 34 | One more possibility to throw into the mix. On my truck that problem was caused a bad brake hose on one front wheel. replacing the hose took care of the problem entirely
Jon 1942 Chevy 3/4-ton Special
I don't need instructions. I have a hammer.
| | | | | Joined: Jul 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 54 | Besure to check your shocks, a broken shock can cause you truck to pull to the side with the bad shock. | | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | Wheel alinment will also cause a pull when braking. Check your front end from brakes to bearings to ball joints, (or king pins) My experiance with leeking wheel cyls, is the offending wheel locks when braking.
"It ain't a truck if you can't hose out the cab."
| | | | | Joined: Dec 2005 Posts: 47 Member | | Member Joined: Dec 2005 Posts: 47 | Tire pressure could cause some pulling but you seem to have a mechanical problem. Sounds like tear down time.
Heres to us and those like us, theres darn few left.
