3 members (jay d, 2 invisible),
54
Mod | | | Forums66 Topics128,009 Posts1,055,292 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 8 Junior Member | | Junior Member Joined: Jul 2005 Posts: 8 | Can someone tell me a web site that will tell me what engine I have in my 66 SWB? I do not believe it is what came as stock. The block casting # is 3877178C GM25. I think it may be from a '62 possibly a 235? I have been on this site since last summer in the lurking mode, but have learned alot from you guys about my 66. Thanks, Rick
Never read the small print...There is no way you're gonna like it!
| | | | | Joined: Jan 2006 Posts: 42 Junior Member | | Junior Member Joined: Jan 2006 Posts: 42 | Welcome, to the site Rick. I am new also here, sorry I don't have an anwer, but I was wondering where did you find the casting number? I have a 66 GMC with a Chevy v8. Thanks in advance,and again welcome to the Bolt!
jcf
| | | | | Joined: Jul 2005 Posts: 8 Junior Member | | Junior Member Joined: Jul 2005 Posts: 8 | My is a six cylinder and the casting was on the passenger side near the bottom front of the block. Sorry cannnot help you with your v-8.
| | | | | Joined: Dec 2005 Posts: 47 Member | | Member Joined: Dec 2005 Posts: 47 | Rick, you have either a 230 or 250 engine. Most likely it is a 230. On the 8 cylinder engine the casting number is on the driver side rear of the engine, just above the bellhousing or transmission depending on which trans you have. There are several sites that give you breakdowns on casting numbers.
Heres to us and those like us, theres darn few left.
| | | | | Joined: Jan 2006 Posts: 42 Junior Member | | Junior Member Joined: Jan 2006 Posts: 42 | Thank you, I'll try finding it again(I am having a hard time with this one)
jcf
| | | | | Joined: Jul 2005 Posts: 8 Junior Member | | Junior Member Joined: Jul 2005 Posts: 8 | James can you give me a website to check the casting number?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy guys, that casting number comes back to a 1963-78 230 or 250 hope this helps | | | | | Joined: Jul 2005 Posts: 8 Junior Member | | Junior Member Joined: Jul 2005 Posts: 8 | Is there a way to determine if it is a 230 or 250? :confused:
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | the v/8 number is on the bellhousing/ drivers side just below the intake maninfold | | |
