| | | Forums66 Topics128,014 Posts1,055,330 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 8 Junior Member | | Junior Member Joined: Mar 2006 Posts: 8 | Hello, My 66 originally was a 3 on the tree shifter.Before I bought the truck from my brother three years ago he converted it to the floor.I'm not sure what brand kit he used but it's not a hurst. My problem is the throw in between gears is really far.Is there a kit to shorten the throw or maybe a better shifter kit?I have a four speed granny top loader in my shed but am a little lazy at the moment to install it. Any help would be appreciated. Daryl.  | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | It's a little hard to say whether yours could be shortened or not, with out seeing it. Hurst made a short shifter for 4 speeds I don't remember seeing one for a 3 spd. There are several factors affecting the the throw. The lenght of the shift lever from knob to pivot point, and the lenght of the lower shift lever from pivot point to rod linkage. The shorter these are the shorter the throw. Another consideration might be the angle of the shift lever. If it isn't already back to the seat you might want to see if it be made to get there. You might take a look at the shifters on that auction sight and compare to yours. Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | where ya going with a stovebolt?????Doze the power shift matter???
dan-pa
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Don't put the old granny in. You won't be happy. Mine is buried behind my garage. | | | | | Joined: Mar 2006 Posts: 8 Junior Member | | Junior Member Joined: Mar 2006 Posts: 8 | The shift lever I have in now is bent back to the seat already and I thought about shortening the stick. The linkage from stick to tranny is prety close now.Maybe I will see about a shorter stick. As for the old granny tranny I have out in the shed I don't really have any plans on putting it in soon.I'm kinda holding out for a real 4 speed.This truck has a 327 from a camaro in it that a previous owner installed that is pretty quick but left the original 3 speed in it. Thanks all, Daryl | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | Sounds like it might be time to go to the junk yard or a swap meet and get the tranny you want before you fuss with this one too much. Good luck.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Jan 2006 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 67 | how about a junkyard S-10 5 speed??? ( if u want to do the 327 justice:)
red (mostly) 1963 chevy shortbed stepside
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Just in case you go with a t5 I changed the shifter throw on mine with a little work ond no $ ask if you want info. | | |
