2 members (Niels V, Hush),
79
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | My '62 Suburban has the hydraulic clutch and a single reservoir brake master integrated together. I need to convert it to a dual reservoir brake master, and keep the hydraulic clutch. Anyone got any tips, pointers and suggestions? Keeping the single res. brake master is NOT an option. Thanks for any input, -Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Nov 2004 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 61 | some companies such as classic performance products make them for brake system upgrades. www.classicperform.com | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Research and buy a hydraulic master just for the clutch. A lot of vehicle use hydraulic clutches, Scott | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | www.mpbrakes.com sells an expensive kit for that. | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | finding the hydraulic master for the clutch isn't a big deal- Try speedway motors.com. I got one for about $50. Mounting it is the trick. I went to a metal working shop and had them drill three holes in a piece of plate steel to match the mating/mounting surface of the master cylinder. Then I cut and welded the rest at home. If you can't do that, you can build your mount from cardboard and take it to a metalworking shop and they'll put it together for you for pretty cheap. Lots cheaper than paying someone else to do the same thing.
| | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | finding the hydraulic master for the clutch isn't a big deal- Try speedway motors.com. I got one for about $50. Mounting it is the trick. I went to a metal working shop and had them drill three holes in a piece of plate steel to match the mating/mounting surface of the master cylinder. Then I cut and welded the rest at home. If you can't do that, you can build your mount from cardboard and take it to a metalworking shop and they'll put it together for you for pretty cheap. Lots cheaper than paying someone else to do the measuring, make the cardboard mock up, have it fabed and then bolt it in.
| | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Finding the right dual master cylinder/combination valve and residual valves isn't a big deal either. CPP's website is a good place to start to get some ideas. What i'd do is go to a junk yard, find a truck of a similar size/weight and pull the master cylinder and combination valve. Alternately, go to autozone/napa etc... and buy a dual master cylinder and combination valve from a similar size weight truck from a newer year.
