4 members (HandyAndy, '37 barn find, cmayna, ESum), 117 guests, and 6 robots.
Topics128,210
Posts1,057,465
Members48,471
My '62 Suburban has the hydraulic clutch and a single reservoir brake master integrated together. I need to convert it to a dual reservoir brake master, and keep the hydraulic clutch.
Anyone got any tips, pointers and suggestions?
Keeping the single res. brake master is NOT an option.
Thanks for any input,
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
some companies such as classic performance products make them for brake system upgrades.
www.classicperform.com
Research and buy a hydraulic master just for the clutch. A lot of vehicle use hydraulic clutches,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Z
Z Offline
www.mpbrakes.com sells an expensive kit for that.
finding the hydraulic master for the clutch isn't a big deal- Try speedway motors.com. I got one for about $50. Mounting it is the trick. I went to a metal working shop and had them drill three holes in a piece of plate steel to match the mating/mounting surface of the master cylinder. Then I cut and welded the rest at home. If you can't do that, you can build your mount from cardboard and take it to a metalworking shop and they'll put it together for you for pretty cheap. Lots cheaper than paying someone else to do the same thing.
finding the hydraulic master for the clutch isn't a big deal- Try speedway motors.com. I got one for about $50. Mounting it is the trick. I went to a metal working shop and had them drill three holes in a piece of plate steel to match the mating/mounting surface of the master cylinder. Then I cut and welded the rest at home. If you can't do that, you can build your mount from cardboard and take it to a metalworking shop and they'll put it together for you for pretty cheap. Lots cheaper than paying someone else to do the measuring, make the cardboard mock up, have it fabed and then bolt it in.
Finding the right dual master cylinder/combination valve and residual valves isn't a big deal either. CPP's website is a good place to start to get some ideas. What i'd do is go to a junk yard, find a truck of a similar size/weight and pull the master cylinder and combination valve. Alternately, go to autozone/napa etc... and buy a dual master cylinder and combination valve from a similar size weight truck from a newer year.
